Merhabalar internet gidip geldi ve 14 mbps yani adsl hıza düştü TurkNet Online İşlem Merkezi de 18 mbps buluşuyor diyor normalde paketim 50 mbps
Eski hat değerleriniz var mı elinizde ve şimdi ki?
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 0
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end FEC error fast: 0
near-end CRC error fast: 28991
near-end HEC error fast: 0
far-end FEC error fast: 0
far-end CRC error fast: 373
far-end HEC error fast: 0
DSL uptime :8 days, 17:28, 2 secs
DSL activetime :0 min, 22 secs
Downstream:
noise margin downstream: 8.5 dB
output power upstream: 7.2 dbm
attenuation downstream: 13.4 dB
Upstream:
noise margin upstream: 16.6 dB
output power downstream: 13.8 dbm
attenuation upstream: 0.7 dB
Bit table:
tone 0- 31: 00 00 00 00 00 00 11 13 33 33 33 34 44 54 44 54
tone 32- 63: 07 77 88 79 98 99 89 9a aa a9 aa a9 aa aa ba ab
tone 64- 95: aa ba aa ba ba bb bb bb cb cb bc bc bb bc bb bc
tone 96-127: bb bc bb bc bc cb bc bb bb bc bb cc bc cb cb cb
tone 128-159: cb bc bc bb bb bb ba cc bb bb bb cb cb cb bb bb
tone 160-191: bb bb bb ba ab ba aa aa aa aa aa ab aa aa aa aa
tone 192-223: aa aa aa aa aa aa aa aa aa aa aa ba aa aa ba aa
tone 224-255: ba aa aa aa aa aa aa aa aa ba ab aa aa ba aa aa
Dünkü
Şimdi ki
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 22434
INP upstream: 15072
reinGINPupstream: 0
near-end fast channel bit rate: 18443 kbps
far-end fast channel bit rate: 531 kbps
near-end FEC error fast: 655790
near-end CRC error fast: 3930
far-end CRC error fast: 325
DSL uptime :24 min, 22 secs
DSL activetime :0 min, 19 secs
Downstream:
output power upstream: 8.2 dbm
attenuation downstream: 26.8 dB
Upstream:
noise margin upstream: 8.4 dB
output power downstream: 14.2 dbm
attenuation upstream: 29.9 dB
Bit table:
tone 0- 31: 00 00 00 44 66 66 77 77 88 77 77 67 76 56 55 43
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 22
tone 64- 95: 20 34 44 32 44 55 43 34 45 53 46 67 64 44 56 56
tone 96-127: 66 65 65 55 45 45 55 55 56 66 64 55 66 67 77 76
tone 128-159: 66 56 77 77 77 77 67 75 66 67 67 77 77 77 67 77
tone 160-191: 77 87 78 78 87 88 78 89 88 88 89 98 89 99 99 98
tone 192-223: 89 99 99 98 89 99 99 98 98 87 88 88 88 77 77 77
tone 224-255: 77 77 77 00 00 00 00 00 00 00 00 00 00 00 00 00
Bu değer değişmiş. Acaba kopma olduğu zaman binanızda konuşunuza internet hizmeti bağlandı mı? Eğer binaya gelen giden yoksa modemi kapatıp açın spliter varsa onu söküp modemi direkt bağlayın. Spliter yoksa bile modeme giren DSL soketini çıkarıp tekrar takın. DSL kablosunda ek varsa kontrol edin. Bunun dışında eğer açmadı iseniz hemen Bir destek kaydı açın. Modeme ulaşması gereken hız ulaşmıyor başlığı altından.
Destek kaydı açtım direkt prizden bağlı
Kapatıp açtım düzelmedi
Hattınızda bir zayıflama söz konusu eğer saha dolabında bir işlem olmadı ise ankastrede yapılan bir işlem veya daha önce yapılmış bağlantının gevşemesi buna sebep olabilir. Veya yine bina ile santral arasında bir problem olabilir. Destek kaydı üzerinden gelecek cevabı beklemenizi öneririm Umarım sorununuz kısa sürede çözülür
Saha dolabı yakın ekip var mı diye bakayım bari
Dışarı çıkınca ankastreye de bir bakın eğer ankastre varsa.
Ankastreye de baktım aynı duruyor işleö yok.
Saha dolabında da kimse yok.
O zaman destek kaydını bekleyin umarım kısa sürede çözülür
1ilerine sordun mu buraya tt geldi mi diye
Merhaba @CandBooM, ben bu süreçte size yardımcı olmaya ve hızlandırmaya çalışayım. Bana açtığınız destek kaydınızın numarasını özel mesaj üzerinden iletir misiniz?
Herkesin aklında haklı bir şüphe
Özelden ilettim destek numaramı
Baktım da gelen giden kimse yok.
Hızlıca arkadaşlarıma ileterek size yardımcı olmaya çalışacağım. Teşekkür ederim.
Teşekkür ederim yardımlarınız için
