Net birden kesilip gidiyor sonra dsl geliyor ama ethernet gelmiyor, kapatıp açınca düzeliyor.
2024-04-02 08:55:58 kernel: PsRetrieveTimeout() Recover ps state(state 1 to state 5) [wcid = 2]!!
2024-04-02 09:37:35 kernel:
2024-04-02 09:37:35 kernel: PTM reset hold
2024-04-02 09:37:35 kernel: tpstc_txRxReset
2024-04-02 09:37:35 kernel: Link State: DSL link down.
2024-04-02 09:37:35 kernel: Link State: PVC_80 PPPoE down.
2024-04-02 09:37:39 WAN Connection: Wan link down.
2024-04-02 09:37:39 stop_nat_rules: apply the redirect_rules!
2024-04-02 09:38:16 syslog: No response to 10 echo-requests
2024-04-02 09:38:16 syslog: Serial link appears to be disconnected.
2024-04-02 09:38:16 syslog: Connect time 1015.8 minutes.
2024-04-02 09:38:16 syslog: Sent 433143801 bytes, received 886037947 bytes.
2024-04-02 09:38:16 syslog: LCP down.
2024-04-02 09:38:22 syslog: Connection terminated.
2024-04-02 09:38:22 syslog: Modem hangup
2024-04-02 09:38:22 syslog: LCP down.
2024-04-02 09:38:26 syslog: LCP is allowed to come up.
2024-04-02 09:39:01 syslog: Timeout waiting for PADO packets
2024-04-02 09:39:01 syslog: Unable to complete PPPoE Discovery
2024-04-02 09:39:01 syslog: LCP down.
2024-04-02 09:39:05 syslog: LCP is allowed to come up.
2024-04-02 09:39:41 syslog: Timeout waiting for PADO packets
2024-04-02 09:39:41 syslog: Unable to complete PPPoE Discovery
2024-04-02 09:39:41 syslog: LCP down.
2024-04-02 09:39:45 syslog: LCP is allowed to come up.
2024-04-02 09:40:20 syslog: Timeout waiting for PADO packets
2024-04-02 09:40:20 syslog: Unable to complete PPPoE Discovery
2024-04-02 09:40:20 syslog: LCP down.
2024-04-02 09:40:24 syslog: LCP is allowed to come up.
2024-04-02 09:40:59 syslog: Timeout waiting for PADO packets
2024-04-02 09:40:59 syslog: Unable to complete PPPoE Discovery
2024-04-02 09:40:59 syslog: LCP down.
2024-04-02 09:41:03 syslog: LCP is allowed to come up.
2024-04-02 09:41:22 kernel: Link State: DSL link up.
2024-04-02 09:41:22 kernel: PTM reset release
2024-04-02 09:41:22 syslog: PPP session is 50037
2024-04-02 09:41:22 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:41:22 syslog: Using interface ppp80
2024-04-02 09:41:22 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:41:22 syslog: PAP authentication succeeded
2024-04-02 09:41:22 syslog: peer from calling number D4:C1:C8:92:0C:50 authorized
2024-04-02 09:41:22 syslog: local IP address 100.113.163.152
2024-04-02 09:41:22 syslog: remote IP address 172.17.1.64
2024-04-02 09:41:22 syslog: primary DNS address 193.192.98.8
2024-04-02 09:41:22 syslog: secondary DNS address 212.154.100.18
2024-04-02 09:41:23 dnsmasq[2395]: exiting on receipt of SIGTERM
2024-04-02 09:41:23 dnsmasq[9510]: started, version 2.78 cachesize 150
2024-04-02 09:41:23 dnsmasq[9510]: using nameserver 212.154.100.18#53
2024-04-02 09:41:23 dnsmasq[9510]: using nameserver 193.192.98.8#53
2024-04-02 09:41:23 dnsmasq[9510]: reading /etc/resolv.conf
2024-04-02 09:41:23 dnsmasq[9510]: ignoring nameserver 127.0.0.1 - local interface
2024-04-02 09:41:23 dnsmasq[9510]: bad address at /etc/hosts line 2
2024-04-02 09:41:23 dnsmasq[9510]: read /etc/hosts - 5 addresses
2024-04-02 09:41:23 kernel: [route_setting]remove interface[0]=[ppp80]
2024-04-02 09:41:23 kernel: Link State: PVC_8_0 logistic interface up.
2024-04-02 09:41:23 kernel: [qos_execute(9375)]:Force Turn Off Bandwidth Limiter on Guest Network.
2024-04-02 09:41:24 WAN Connection: Wan link up.
2024-04-02 09:41:24 syslog: Modem hangup
2024-04-02 09:41:24 kernel: nas8: stoping interface.
2024-04-02 09:41:24 syslog: Connect time 0.1 minutes.
2024-04-02 09:41:24 syslog: Sent 1131 bytes, received 396 bytes.
2024-04-02 09:41:24 syslog: Connection terminated.
2024-04-02 09:41:24 syslog: LCP down.
2024-04-02 09:41:24 syslog: Terminating on signal 15
2024-04-02 09:41:26 kernel: [smuxctl rem nas8_X]
2024-04-02 09:41:26 kernel: $s: go into unregister_mulif_device
2024-04-02 09:41:26 kernel: nas8_0: vifname = unregister_mulif_device
2024-04-02 09:41:26 kernel: Release MAC when router interface unregister
2024-04-02 09:41:26 kernel: mulif_release_MacAddress
2024-04-02 09:41:26 kernel: nas8_1: vifname = unregister_mulif_device
2024-04-02 09:41:26 kernel: vdev is NULL
2024-04-02 09:42:01 WEB: User [admin] logged in from [192.168.1.201] via WEB
2024-04-02 09:42:02 syslog: LCP is allowed to come up.
2024-04-02 09:42:02 syslog: PPP session is 50138
2024-04-02 09:42:02 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:42:02 syslog: Using interface ppp80
2024-04-02 09:42:02 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:42:02 syslog: Remote message: Authentication failed!
2024-04-02 09:42:02 syslog: PAP authentication failed
2024-04-02 09:42:02 syslog: LCP down.
2024-04-02 09:42:03 kernel: Rcv Wcid(1) AddBAReq
2024-04-02 09:42:03 kernel: Start Seq = 00000248
2024-04-02 09:42:08 syslog: Connection terminated.
2024-04-02 09:42:08 syslog: Modem hangup
2024-04-02 09:42:08 syslog: LCP down.
2024-04-02 09:42:13 syslog: LCP is allowed to come up.
2024-04-02 09:42:13 syslog: PPP session is 50149
2024-04-02 09:42:13 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:42:13 syslog: Using interface ppp80
2024-04-02 09:42:13 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:42:13 syslog: Remote message: Authentication failed!
2024-04-02 09:42:13 syslog: PAP authentication failed
2024-04-02 09:42:13 syslog: LCP down.
2024-04-02 09:42:19 syslog: Connection terminated.
2024-04-02 09:42:19 syslog: Modem hangup
2024-04-02 09:42:19 syslog: LCP down.
2024-04-02 09:42:23 syslog: LCP is allowed to come up.
2024-04-02 09:42:23 syslog: PPP session is 50163
2024-04-02 09:42:23 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:42:23 syslog: Using interface ppp80
2024-04-02 09:42:23 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:42:24 syslog: Remote message: Authentication failed!
2024-04-02 09:42:24 syslog: PAP authentication failed
2024-04-02 09:42:24 syslog: LCP down.
2024-04-02 09:42:30 syslog: Connection terminated.
2024-04-02 09:42:30 syslog: Modem hangup
2024-04-02 09:42:30 syslog: LCP down.
2024-04-02 09:42:34 syslog: LCP is allowed to come up.
2024-04-02 09:42:34 syslog: PPP session is 50218
2024-04-02 09:42:34 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:42:34 syslog: Using interface ppp80
2024-04-02 09:42:34 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:42:34 syslog: Remote message: Authentication failed!
2024-04-02 09:42:34 syslog: PAP authentication failed
2024-04-02 09:42:34 syslog: LCP down.
2024-04-02 09:42:40 syslog: Connection terminated.
2024-04-02 09:42:41 syslog: Modem hangup
2024-04-02 09:42:41 syslog: LCP down.
2024-04-02 09:42:45 syslog: LCP is allowed to come up.
2024-04-02 09:42:45 syslog: PPP session is 50238
2024-04-02 09:42:45 syslog: Connected to d4:c1:c8:92:0c:50 via interface nas8_0
2024-04-02 09:42:45 syslog: Using interface ppp80
2024-04-02 09:42:45 syslog: Connect: ppp80 <–> nas8_0
2024-04-02 09:42:45 syslog: Remote message: Authentication failed!
2024-04-02 09:42:45 syslog: PAP authentication failed
2024-04-02 09:42:45 syslog: LCP down.
