Hocam bilgileriniz yanlış.
Vr2100 mediatek chipsetli
Vr600 v3 mediatek chipsetli v2 ve v1 sanırım broadcom
VR2800 için broadcom demiş sanırım. Sorun modemlerde değil aslında sorun dandik bakır altyapıda.
If you can afford it , get the VR2800 , it has better , faster wifi , more ram and uses a Broadcom chipset than the VR2100…
The VR2100 uses a MediaTek chipset and is not really the best for long lines , but could be different in the UK , but since you are in a rural area with a long line and possible dodgy lines you are better off getting a modem with a Broadcom chipset as they are more
forgiving and stable on long or noisy lines.
The VR2100 is built to a price and with the cheaper MediaTek chipset and , I think it can run a bit hot , however , going by some reports on WP , the VR2100 is fairly stable , but that can depend on the distance to the node , if you are less than 1 km from the closest node , then the VR2100 should be fine.
The VR900 is also fairly good , uses a Broadcom chipset as well , however ver 1 and ver 2 of this model uses the older TP-Link firmware , so it would be best to get the ver 3 if available in your area as it has the newer TP-Link firmware.
The main difference between the VR600 and VR900 is mostly the speed / rating on the wifi , the VR600 has AC1600 wifi , the VR900 has AC1900 wifi , so if you have been happy with the VR600 , then the VR900 will be the same with the slightly faster wifi , and the VR2800 will feel a lot more quicker because of the faster AC2800 MU-MIMO wifi and better hardware specs.
As for the type of connection you have , FTTN is VDSL and you connect to it by plugging a vdsl modem into a standard telephone socket.
With FTTC connection , a Network Termination Device ( NTD ) is a reverse powered modem that plugs into a standard telephone socket and then the user plugs a router into the NTD .
Merhaba @hommate01, öncelikle yaşamış olduğunuz sorun nedeniyle üzgün olduğumuzu bilmenizi isterim. Ancak hatlarda yaşanılan CRC ve FEC hatalarının sebebi lokasyonda yaşanılan kablo arızaları, iç tesisat ve donanımsal sorunlar nedeniyle yaşanıyor
Yine de ne olur ne olmaz biz de inceleyelim. Bize daha önce sorununuz ile ilgili bir kayıt oluşturdunuz mu?
arıza biraktım port degimi yapildı bugun ama degisimden sonra 4 saat icinde 400 bine yakin crc hatası verdi
Farklı bir modem ile deneme şansınız var mı?
asus dsl n16 ile test ettim onda crc hatasi verdi ama zyxel broadcom modem ile test ettim hata vermedi
keenetic hero dsl de testlerim
3,6,12 yazılım atınca crc durumu 1 ci resim. 30000
3,7,2 yazlım atınca crc 3,5 milyon oldu 2 ci resim 3500000
aynı cıhaz yazılım farkı ne kadar farkettı…
yazilimla belkide crc hatalarini ort bas yapiyorlardir cunki benim cihazada crc yazilimi yaptilar crc hic olmuyordu sozde.
1,5 aylık test surecımız oldu servısle yaklasık
en sonunda hepsını pas gectım ust model brodcomlu snr ayarlı modem alacaktım cok pahalı uymuyor bana
genelde sorun yasayanlar brodcom cipsetlı saha dolapları sanırım benım cıhaz farklı cıpsetı oldugu ıcın 3,612 yazlıma kadar crc cok dusuktu 3,7,1 den ıtıbaren crrc cok asırı arttı ve kopmalar oldu.
servıs bır cok test yazılım denedı fakat sonuca baglayamadık dun kafam bozuldu…crc ve kopma sorunu ıcın test yazlım verdıler bırcok derken bır tanesı tuttu,kac defa bu ozellıklerı yenı yazlımıda koyunku ılerde guncelleeme alınca aynı sorun yasamayım(cunku benım gıbı aynı sorunu yasayanlar oldu kac kısı) aynı model cıhazlarda,koyamayız dedıler…
ya bu sekıl kullanın dedıler guncelleme olmadan devam etmektekse aynısorunları yasamak olacagı ıcın devamında ne anlamı kaldıgı dsl modem aldıgım
1-modemı satıp ust modem brodcom cıpli snr ayarlı modem alacagım
2-tplink td9970v3 modemde dusmuyor + hero dsl router olarak kullanmak
3-yada en son care test 3,6,12 veya test yazılım verdıler uyumlu onu sabıt kullanmak guncelleme kapalı tutarak
bu sorun 3,6,12 yazlıma kadar yoktu 3,7,1 den ıtıbaren cıktı genelde saha dolabı brodcom cipsetı olanlarda yasandı sorun.
servıs devemanı 1,5 aylık ugrasta getırmedı dun silş yenı bastan kaldım.
yazlımda 3,6,12 den sonra bırseylerı kaldırılar oda bıze yaramadı…
yazlımlar cok cok etkılı oluyor crc ce kopmalar ıcın.
mantiken bakildigi zaman modem dslam uyumu elbetrmte goz ardi edilememeli uyum icin
Yazilim onemli…yazilimdan yazilima degisebiliyor sorun duzelme olayi yukarda attigim resimde gayet acik sekilde
bu modem adami kanser eder 2014 zyxel broad com modem bi tane bile crc vermezken bu modem milyarlarca hata veriyor
İşte internet erişiminde modemin önemi
vdsl kullaniyorsaniz saha dolabina 100 metreden fazla uzaksaniz broadcom modem alin kesinlikle
broadcom modem ise sorun olmaz
