Hattı bağlatırken 70 küsür bit civarı Vaad edilmişti ama 60 civarı olduğunu söyledi arkadaş bu sorun değil ancak şuan gelen hız çok dalgalı bir anda 30mbit bir anda 50. Modem değerlerimide aşağıya atıyorum. yardımlarınızı bekliyorum.
Annex Mode: ANNEX_B
INP downstream: 52318
INP upstream: 14870
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end fast channel bit rate: 54926 kbps
near-end FEC error fast: 2380270104
near-end CRC error fast: 62186909
near-end HEC error fast: 0
far-end FEC error fast: 0
far-end CRC error fast: 105
far-end HEC error fast: 0
DSL uptime :6 days, 15:26, 2 secs
Downstream:
noise margin downstream: 8.6 dB
output power upstream: 8.6 dbm
attenuation downstream: 9.8 dB
Upstream:
noise margin upstream: 11.0 dB
attenuation upstream: 20.5 dB
Bu da bugun bağlantımı yeniledikten sonra hat değerlerim.
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 12820
INP upstream: 14848
reinGINPupstream: 0
near-end fast channel bit rate: 64619 kbps
near-end FEC error fast: 148
near-end CRC error fast: 15
far-end CRC error fast: 0
DSL uptime :27 min, 33 secs
Downstream:
noise margin downstream: 6.0 dB
output power upstream: 8.8 dbm
attenuation downstream: 10.4 dB
Upstream:
noise margin upstream: 11.2 dB
attenuation upstream: 20.3 dB
