bu modem değerlerine sahip olmama rağmen hızım sürekli düşürülüyor. Bana alabileceğim max hız 70 mb/s diyorlar ama 28 mb alıyorum, sürekli kopma oluyor diye. ( ilk başta 60mb/s hıza sahiptim kompa oluyor diye 50 yaptılar yine kopma oldu 35 yaptılar ama 28 alıyorum)
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 0
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 0 kb/s
near-end fast channel bit rate: 35838 kb/s
far-end interleaved channel bit rate: 0 kb/s
far-end fast channel bit rate: 2046 kb/s
near-end FEC error fast: 0
near-end CRC error fast: 5471
near-end HEC error fast: 0
far-end FEC error fast: 0
far-end CRC error fast: 0
far-end HEC error fast: 0
DSL uptime :1 day, 2:45, 14 secs
Downstream:
noise margin downstream: 15.0 dB
output power upstream: 6.5 dbm
attenuation downstream: 4.7 dB
Upstream:
noise margin upstream: 28.2 dB
output power downstream: 13.3 dbm
attenuation upstream: 11.4 dB
Bit table:
tone 32- 63: 00 00 00 00 00 00 00 10 31 22 24 23 23 32 30 21
tone 64- 95: 11 03 02 01 21 30 21 23 14 13 21 31 30 22 12 13
tone 96-127: 02 20 21 30 22 12 13 10 11 20 00 02 00 10 02 00
tone 128-159: 12 22 32 22 22 22 32 33 33 34 34 44 34 43 45 44
tone 160-191: 45 45 45 55 65 65 76 66 67 67 77 67 87 77 78 78
tone 192-223: 77 87 77 87 78 78 78 87 77 87 87 88 78 88 88 88
tone 224-255: 88 88 88 89 98 88 89 88 88 a9 99 8a 99 99 99 99
