Hattımdaki tanımlı hızım düşmüş ve deli gibi crc ve fec hataları yemişim birde bunlar 0 dı yükselmiş normalde 77.99 mbps tanımlıydı
INP downstream: 22020
INP upstream: 14820
Hat değerlerim.
Line State: Up
Annex Mode: ANNEX_B
INP upstream: 14820
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end fast channel bit rate: 72563 kbps
near-end FEC error fast: 27356
near-end CRC error fast: 2405
near-end HEC error fast: 0
far-end FEC error fast: 0
far-end CRC error fast: 0
far-end HEC error fast: 0
DSL uptime :10:35, 40 secs
DSL activetime :0 min, 22 secs
Downstream:
noise margin downstream: 12.0 dB
output power upstream: 5.1 dbm
attenuation downstream: 7.4 dB
Upstream:
noise margin upstream: 26.7 dB
output power downstream: 14.5 dbm
attenuation upstream: 0.0 dB
Bit table:
tone 32- 63: 07 87 77 76 66 66 66 66 66 65 55 55 55 55 55 55
tone 64- 95: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
tone 96-127: 56 66 66 66 66 66 77 77 77 77 88 77 77 77 77 66
tone 128-159: 66 66 55 66 65 55 55 55 55 55 55 55 45 56 66 55
tone 160-191: 55 55 55 55 55 65 65 66 56 65 55 66 66 65 66 66
tone 192-223: 66 66 66 66 66 66 76 67 76 66 66 67 77 67 77 77
tone 224-255: 77 77 77 77 77 67 76 77 77 77 77 77 77 77 76 77
