Merhaba
Değerlerime bir bakabilir misiniz? Ben pek anlamıyorum da
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 0
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end fast channel bit rate: 35838 kbps
far-end fast channel bit rate: 6143 kbps
near-end FEC error fast: 0
near-end CRC error fast: 1470
near-end HEC error fast: 0
far-end FEC error fast: 27417
far-end CRC error fast: 35
far-end HEC error fast: 0
DSL uptime :17:10, 48 secs
Downstream:
noise margin downstream: 8.5 dB
output power upstream: 9.4 dbm
attenuation downstream: 10.3 dB
Upstream:
noise margin upstream: 13.8 dB
output power downstream: 13.6 dbm
attenuation upstream: 16.1 dB
Bit table:
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 01 00 02 02 22
tone 32- 63: 20 02 23 43 45 55 55 66 66 66 66 66 65 55 55 57
tone 64- 95: 76 76 76 75 67 67 57 66 67 77 77 88 99 89 98 99
tone 96-127: 99 98 89 98 89 99 99 88 88 88 78 77 77 67 77 77
tone 128-159: 77 77 77 77 76 77 76 66 66 55 55 55 55 66 65 66
tone 160-191: 77 67 67 77 77 77 77 87 77 87 77 77 77 77 77 77
tone 192-223: 66 76 55 66 55 55 55 55 56 65 56 66 65 56 66 66
tone 224-255: 67 67 76 77 66 77 76 77 77 78 78 77 77 87 87 78
