ZyXEL VMG8623-T50B modem kullanıyorum.
Modem arayüzünden Log ekranına girmeye çalışıyorum ama giremiyorum, sizde de aynı mı?
Modemi yeniden başlantınca geçen bi problemin modem dışında bir şeyden kaynaklanma ihtimali var mıdır? Benim kablo bağlantım veya beni aşan şeyler vs.
Burada size garip gelen bir şey var mı?
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 0
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end fast channel bit rate: 35838 kbps
far-end fast channel bit rate: 6142 kbps
near-end FEC error fast: 0
near-end CRC error fast: 27
near-end HEC error fast: 0
far-end FEC error fast: 3
far-end CRC error fast: 2
far-end HEC error fast: 0
DSL uptime :46 min, 22 secs
Downstream:
noise margin downstream: 12.3 dB
output power upstream: 9.4 dbm
attenuation downstream: 18.9 dB
Upstream:
noise margin upstream: 14.9 dB
output power downstream: 13.3 dbm
attenuation upstream: 8.7 dB
Bit table:
tone 0- 31: 00 00 00 00 11 10 01 11 12 22 44 33 35 55 55 55
tone 32- 63: 45 54 56 66 66 66 66 66 66 66 66 65 55 55 55 55
tone 64- 95: 55 55 55 65 55 55 55 55 55 54 55 54 45 45 45 44
tone 96-127: 55 55 55 55 45 45 44 45 45 44 44 44 44 44 45 44
tone 128-159: 44 44 44 34 44 44 43 43 34 24 34 44 44 45 55 55
tone 160-191: 55 55 55 55 56 56 55 66 76 66 66 66 66 66 67 66
tone 192-223: 66 66 66 35 55 56 66 76 66 65 76 67 77 78 77 77
tone 224-255: 78 88 88 88 88 88 98 68 98 88 88 88 88 88 98 88
