Diğerleri ile ilgili yeni anlaşmalar yapıldı mı yapılmadı mı güncel bilgim yok maalesef. @EFG ye Dm olarak sorabilirsiniz
muğla 120ping, oyunlar haram oldu. internet kullanırken kanser olmak zorunda mıyım?
aynı binadaki aynı dolaba bağlı tt saat 22.00,
google.com tracert
tt vdsl: 25ms,
TurkNet vdsl: 66ms
vie.valve.net
tt vdsl: 60ms
TurkNet vdsl 80ms
modemden alınan tracert:
valve TurkNet
traceroute to vie.valve.net (146.66.155.1), 30 hops maximum, 84 byte packets.
1 172.17.1.250 (172.17.1.250) 20.814 ms 20.769 ms 21.053 ms
2 225.100.146.159.srv.turk.net (159.146.100.225) 23.194 ms 23.654 ms 23.027 ms
3 226.100.146.159.srv.turk.net (159.146.100.226) 20.945 ms 21.155 ms 20.697 ms
4 229.100.146.159.srv.turk.net (159.146.100.229) 26.007 ms 27.237 ms 26.311 ms
5 38.22.146.159.static.turk.net (159.146.22.38) 73.015 ms 73.170 ms 73.299 ms
6 95.70.217.106 (95.70.217.106) 70.542 ms 72.660 ms 70.851 ms
7 vie.valve.net (146.66.155.1) 74.112 ms 73.737 ms 73.316 ms
google TurkNet
traceroute to google.com (172.217.17.238), 30 hops maximum, 84 byte packets.
1 172.17.1.250 (172.17.1.250) 21.792 ms 21.765 ms 21.855 ms
2 225.100.146.159.srv.turk.net (159.146.100.225) 23.784 ms 23.983 ms 24.064 ms
3 226.100.146.159.srv.turk.net (159.146.100.226) 22.056 ms 22.176 ms 21.733 ms
4 229.100.146.159.srv.turk.net (159.146.100.229) 28.313 ms 25.103 ms 26.390 ms
5 234.22.146.159.static.turk.net (159.146.22.234) 22.424 ms 22.670 ms 22.252 ms
6 * 195.175.51.209.static.turktelekom.com.tr (195.175.51.209) 22.189 ms 22.785 ms
7 00-gayrettepe-xrs-t2-2—00-gayrettepe-t3-9.statik.turktelekom.com.tr (212.156.121.138) 22.670 ms 22.309 ms 22.494 ms
8 00-ebgp-gayrettepe-k—00-gayrettepe-xrs-t2-2.statik.turktelekom.com.tr (81.212.202.19) 22.265 ms 22.305 ms 22.453 ms
9 307-sof-col-2—00-ebgp-gayrettepe-k.statik.turktelekom.com.tr (212.156.104.156) 31.387 ms 31.693 ms 31.660 ms
10 72.14.204.8 (72.14.204.8) 67.208 ms 67.640 ms 67.017 ms
11 216.239.59.239 (216.239.59.239) 63.842 ms 64.383 ms 64.046 ms
12 209.85.242.141 (209.85.242.141) 64.727 ms 65.417 ms 65.082 ms
13 ber01s08-in-f238.1e100.net (172.217.17.238) 64.094 ms 64.097 ms 64.054 ms
turktelekom google.com wifi
traceroute to google.com (172.217.169.142), 255 hops max
Hop 1:
From 192.168.1.1, 24 ms
Hop 2:
From 212.156.201.146, 27 ms
Hop 3:
From 81.212.2.65, 26 ms
Hop 4:
From 81.212.221.68, 24 ms
Hop 5:
From 81.212.30.7, 23 ms
Hop 6:
From 212.156.104.162, 38 ms
Hop 7:
From 142.250.168.28, 32 ms
Hop 8:
Hop 9:
From 209.85.248.178, 37 ms
Hop 10:
From 216.239.47.153, 28 ms
Hop 11:
From sof02s32-in-f14.1e100.net (172.217.169.142), 28 ms
telekom valve wifi
traceroute to vie.valve.net (146.66.155.1), 255 hops max
Hop 1:
From 192.168.1.1, 2 ms
Hop 2:
From 212.156.201.146, 17 ms
Hop 3:
From 81.212.2.65, 9 ms
Hop 4:
From 81.212.25.3, 15 ms
Hop 5:
From 81.212.197.233, 30 ms
Hop 6:
From 81.212.201.195, 32 ms
Hop 7:
From 212.156.140.188, 49 ms
Hop 8:
From 185.84.16.29, 69 ms
Hop 9:
From ae-1.r21.vienat02.at.bb.gin.ntt.net (129.250.7.20), 85 ms
Hop 10:
From ae-2.r01.vienat02.at.bb.gin.ntt.net (129.250.2.216), 67 ms
Hop 11:
From 83.231.187.6, 65 ms
Hop 12:
From vie.valve.net (146.66.155.1), 65 ms
Cs Go’da 55-60 alıyorum ben. Normal geliyor bana
Rize de yaşıyor olduğumu belirttim. Valve dışında artık İstanbul gidiş geliş süreleride yükseldi. 23 ms ile TurkNet İstanbul sunucusuna ulaşırken artık 34 ms ile ulaşıyorum.
Bursada yaşıyorum değerler bu şekilde
Antalya
ortalama 19ms ile İstanbul süresi şimdi ortalama 22ms.
Bazı yurt dışı kaynaklı sunucular da lokasyon: Denizli> Antalya> Hatay> Denizli> İzmir> Hatay> İzmir> İzmir gibi bir ileri bir geri dolaşımlı gidiyor static Turktelekom tarafından.
Hız konusunda ne kadar iyi olsa da , ping konusunda hüsrana uğrattı beni TurkNet.
bu aralar.gercekten pingler.cok dengesiz haddinden fazla ama sabret sukret dua et. TurkNet nelerin ustesinden geldi onunda gelir insallah bekelemedeyiz .! duzelceginede eminim suan turkiye genelinde sorun oldugunu dusunuyorum.speed test 3 ping di suan istanbuldan 8-10 ms cikiyo
Benim tarafımda nedense yükselme çok fazla. Yarım saat düzeliyor gün içinde 23 oluyor. Sonra hop tekrar 34
Yanlış hatırlamıyorsam sizin hizmetiniz de problem var, @asdas127816 benzer tabi, bu tür etkilenmeler ile daha fazla probleme yol açıyor. Unutmıyalım: Tracert testleri çıkan sonuçların hepsi TurkNet veya kullandığınız ISS ile ilgili değildir Hizmetinizin konumu, değerleri, fiziksel yapısı gibi etkenlerden de etkilenebiliyor ama yukarı da genel bir tablo var yani, postta ki kullanıcıların çoğunluğu yaşamakta bu sorunu.
Pinglere bak, bursadaki adam benden daha düşük,
Antalya daki adam benle aynı pingi alıyor.
İstanbul son durum, uçmuşuz yine…
Ankara’da EU pingleri ucmuş durumda. Yurt İçi Pinglerde sıkıntı yok
Şuan internet felç.
YouTube videoları, Twitch yayınları donuyor sürekli.
Telegram mesajları 10 15 sn de gidiyor.
Speedtest TurkNet sunucusu da patlamış…
Anlık olarak çoğu siteye erişim sorunu yaşıyorum ve gecikme süreleri kötü haldeyken daha kötü hale geldi.
TurkNet sunucuları patlamış galiba.
Evet öyle gözüküyor. Yurtici pingim 43 ms
oyun içi denediniz mi?
