TurkNet’in ZYXEL VMG8623-T50B modemini kullanıyorum. Hat değerlerimi araştırma yapmama rağmen yorumlayamadım. Desteklenen max hız nedir? Üst pakete geçmeli miyim?
Line State: Up
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 0
shineGINPdownstream: 0
shineGINPupstream: 0
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end fast channel bit rate: 35838 kbps
far-end fast channel bit rate: 6141 kbps
near-end FEC error fast: 0
near-end CRC error fast: 39
near-end HEC error fast: 0
far-end FEC error fast: 0
far-end CRC error fast: 0
far-end HEC error fast: 0
DSL uptime :4 days, 8:45, 40 secs
Downstream:
noise margin downstream: 20.9 dB
output power upstream: 8.1 dbm
attenuation downstream: 6.0 dB
Upstream:
noise margin upstream: 23.9 dB
output power downstream: 13.1 dbm
attenuation upstream: 0.1 dB
Bit table:
tone 0- 31: 00 00 00 00 00 00 00 22 24 45 45 55 66 66 77 77
tone 32- 63: 00 34 44 44 55 54 45 56 56 66 66 66 67 77 77 77
tone 64- 95: 77 77 77 78 78 88 88 88 88 88 88 88 88 88 88 88
tone 96-127: 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
tone 128-159: 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
tone 160-191: 88 88 88 88 88 88 88 88 87 78 87 77 77 77 77 78
tone 192-223: 78 78 77 67 67 77 87 77 66 77 77 77 77 77 77 77
tone 224-255: 67 67 76 77 77 77 77 77 77 77 67 77 76 67 76 67
