Değerlerim aşağıdaki gibidir. Destek kaydı da oluşturdum ancak buraya da yazmak istedim. Başına gelen ve çözüm önerisi olan var mıdır? Müşteri No:2390750
Line Rate: 0.454 Mbps 10.602 Mbps
Actual Net Data Rate: 0.426 Mbps 10.562 Mbps
Trellis Coding: ON ON
SNR Margin: 8.1 dB 8.6 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 10.5 dBm 13.2 dBm
Receive Power: -14.9 dBm -7.1 dBm
Total Attenuation: 25.4 dB 20.4 dB
Attainable Net Data Rate: 0.422 Mbps 11.392 Mbps
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 25.4 N/A N/A N/A 18.1 30.9 50.2
Signal Attenuation(dB): 25.4 N/A N/A N/A 18.2 30.9 50.2
SNR Margin(dB): 8.1 N/A N/A N/A 8.6 8.6 8.6
Transmit Power(dBm): 10.5 N/A N/A N/A 10.9 7.6 4.8
